hey i have a 98 sonoma that was bagged and im putting it to stock and selling it. had kp arms on the front and i put stockers on and the uppers arent fitting. like the upper arm goes on but has no movement. . .what is up with this?
Afterhours Admin
its not supposed to move, when the 15/16" nuts are tight on the end of the shaft it locks teeth together to keep the bushing from moving. then the suspension travel is in the flex of the rubber alone.
if you want it to move freely, loosen the nuts. youll have to retighten them at ride height as stated.
