So after painstakingly installing an air-ride setup on my truck, are there some products out there to help keep the bags conditioned?
Newbie
not really, nothing ive ever heard of. After you've put a few miles on it take a look over everything and make sure nothings rubbing on anything. Then when you change your oil make it a habit to glance over your lines and bags to make sure everything's still good. I also recommend draining your air tank every couple of weeks. Get all the water out that's accumulated
I own a 89 Lincoln LSC, it’s got bags all around And I’m still using the originals ! Best advice is to keep them clean , don’t let grit accumulate on the bag as it will rub the folded over rubber portion and cause issue down the road with slow leaks or worse. Bags in general are pretty stout and can take quite a bit of abuse .
