1 - 20 of 20 Posts
"Special" member!!!!!!!!!
Could you find me a full download for this program? Block Web Site Buddy 3.24
Thanks in advance.
Ok here is what I did! I downloaded a free trial version of Block Web Site Buddy and it will let me block the sites but I cant unblock them. You have to buy the full version at $19.99-$39.99 just to use all the features including unblocking. My problem is, I tried to block one persons myspace profile but instead it blocked all myspace profiles. Is there any way I can get around this? I deleted the program but still no luck?????
Help!!!!
that is the trial version again! i need a full version or a crack/registration code for the trial.
Thanks though.
already tried that too^^^^ : ( I would be set if I just could get the program. I dont want to have to pay $20 just to unblock myspace and never use it again.
Bovine on NOS!!
"Block Web Site Buddy backups configuration data so you can roll back all changes at any time."
if you are beyond being able to do that because of uninstalling it, then try cleaning out your registry
^^^What he said......
Discussion Starter #14
I only installed the demo version. In the demo version you cant unblock anything until you buy the full version:(
It probably just edits your hosts file.
C:\WINDOWS\system32\drivers\etc\hosts
get rid of everything in there but the default:
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
IT is easy to unblock a webpage....just right click the webpage u wish to unblock in blockwebsitebuddy n press delete...n it is unblocked...it is so easy:rotf::rotf:
1 - 20 of 20 Posts
