1 - 10 of 10 Posts
there is a post in the how tos on this forum, its very easy to follow, and works perfectly
Look When Backing Up
ok so i am confused i thought the pressure switch whent on the tank or something, where does the pressure switch go and how do you hook the rest up to the tank
What do you mean "the rest"? Yes, the compressor and p switch both connect to the tank, but that has nothing to do with the wiring. It's a wiring diagram, not an airline plumbing diagram.
okok i get it now, does it matter where i mount the relay, like should i do it in the bed by the compressor and pressure switch or should it be inside by the toggle switch?
the relay needs to be as close to the compressor as possible, just as the fuse needs to be as close to the battery as possible.
1 - 10 of 10 Posts
