looking for the digram to wire the compressor and the relays i know someone is gonna post search the forum and i have but i cant find it
What were u sayin nope to?fastbagged2001 said:nope...all I had was 12 ga...so thats what I was using...may have been 16 tho I cant really remember...hey, you use what you have...
This...I wasnt talking about the power wire...Sorry, I should have quoted that...NCHEVYHEVN3 said:If u are talking about the wire to run to tie into the ignition than use 18 gauge. On the left kick panel there should be a pink wire and u can tie into that.
Fastbagged2001 I think u are talking about the power wire.
Yeah,incudose said:is the rocker switch just for if you want to turn the comp off no matter what, kinda like have it laid out so no one can take it unless they find the rocker? getting ready to wire my stuff in next week or so
Yea thats exactly what I have. A rocker switch in the cab thats got 18 gauge from the battery to the switch, then to the relay thats plugged to a ground, the compressors, and then the pressure switch.fastbagged2001 said:Yeah,
I guess...Just dont plan on someone taking the truck tho...I use mine in cause I am asleep in my house and something possibly freaky happens, like a line coming off, or some of my dumb neighbors get drunk and decide to cut an airline or two, or if you have a leak in your system. That way my compressor wont kick on (when I lose pressure in the tank)and run the batt down...Its basically the same as running your pressure switch to your ignition. the comp. wont kick on unless the key is on. well, mine wont kick on unless the switch is on...I don't know if I have explained this good enough but anyway, I think you get the picture...
