I haven't run my truck for almost 2 weeks...When I tried to turn on my AZ compressor with my toggle switch, nothing came on...what should be the first thing that I should look for first???...I just hope that the nothing is wrong with the compressor...
i don't use fuse..i use a circuit breaker for my system...i'll check if the i have any loose connections...The only connections that i looked at so far is the wiring underneath the hood and the circuit breaker...I'm gonna check tomorrow on the wiring going to the relay...How would I know if the pressure switch or the relay is bad?..
Slammedcruiser98
^^ yeah and double check your ground even if its still atached.sometimes they just loose connection from rushed install. not calling you a hack but its one of the last peices of an install and they just get rushed occasionally.
