1 - 10 of 10 Posts
I just installed the ART roadgrater and installed a big red valve system with a 400 viair compressor. It keeps blowing fuses, I have a 8 guage power wire run to it and its says its rated at 30 amps. 30 amp fuses pop at about 120 PSI and the pressure switch is a 150PSI cut off.
Should I up the amp size or is something else wrong?
white guy from lodi
what size air tank do u have because i have a viair450 set up the same way and it hits 150psi on a 12 gal with no prob
white guy from lodi
i have 1 now but i will have 2 tomorrow.i was just saying1 will fill a12gal with out blowing fuses. ofcourse it takes like 20min.
1 - 10 of 10 Posts
