I had 3 extra compression unions i picked up in case of leaks, well after my night of ficing a blown line, i had a leak, bad enough to leak all pressure from tank over night, or during school/work. it was most likely because i was fixing the line in the cold night and on the side of the road in the ghetto..but i put a new fitting on after re-cutting the line and it still leaked..so i tried ANOTHER fitting and got the line a little more straight as i tighttened the nuts. it didnt seem to leak bad, but after 2-3 hours it went down like 7-10 psi. i was wondering if theres anything special like if the line has to be straight and crap on these fittings when you tighten them. thanks
