My S-10 with 134ci SFI failed to start last month after a rather cold night (Sacramento temperatures were between 80 during the day and 60 at night). It turned and turned but never started. About an hour later my tow truck driver gave it a try and it fired right up - much to my embarassment.
I replaced both the battery and alternator and it has been running great until last night when it failed to start again. Same deal, it was the coldest night so far this year (about 40). It turned and turned, even sputtered a few times like it was trying to catch. Hours later, I hopped in, it started right up. I put it on a charger for about an hour. Afterwards the voltage indicated on the instrument panel was right at 14 volts when running. That's higher than since I owned it (I've had it 6 months and it always indicated 10-12 while running).
I'm torn between thinking my cold start problems were due to a poorly charged battery/poor charging capacity/cold temeratures or a problem with the fuel pump electrical system. I've seen some posts that mentioned the fuel pump and TheftLoc systems.
I used to have a '95 with a 262ci and TBI. It had the same 100-amp alternator, and I ran the battery down a few times, but it never refused to start like this '98 has.
Is there any 'trick' with starting this '98 that I'm not aware of? I live in a 'warm' climate, I'm not ready for a block heater and trickle charger.
