Junkyard Master
the transmission in my 98 2.2 reg cab is sticky as hell when it's cold out and it's not warmed up
it is in an as of yet unknown forward gear in neutral
the truck will stall if you lift the clutch completely
doesn't happen when it's warm, started 2 winters ago
after the truck warms up everything goes back to normal
maybe related 1st won't engage unless the truck is totaly stopped, especialy when cold, but basicaly always
change the fluid if you have not done that since the problem started using synthetic fluid usually also helps the reason for it not going in to gear without being stopped is problem worn sincros
