Still plays with sparks
well whats the differance? is it that the V6 coil is designed for more weight? Or is it not that at all? Basicaly, can I put a coil for a 6 in a truck w/a 4? and if so, what are the effects?
Trick MotorSports!
yeah, the V6 coils have a higher spring coefficient for the added weight. Drop V6 Coils on a 4cyl won't drop quite as much, maybe .25-.5" less
Paint Needing Mofo
Tha_Boom said:
also won't it be stiffer?
It sure will, It's gonna have a higher spring rate. I don't know the actual numbers though... Does anyone know what the spring rate is for our coils?
Treadwear Waste'n Member
Dont do it man!
I put V6 springs in my 4 banger when the ****-o's at summit screwed up my order. It lifted the truck! The nose was waaaaaay in the air!:cry:
BTW: they were the 1" springs.
