Possible dumb question, but how safe is it for someone to mount coilover shocks on the stock mounts for the shocks?
yeah, it helps to at least have any idea what youre asking aboutI probably should be more specific.
what areyou doign with the leaf springs?The rear of the vehicle for the single bolt bottom and double bolt top,
itd be fine for a short time, its not really made to support the weight of the vehicle, but, why, is the real question here. Remember your first sentence "I probably should be more specific..." that would really help here. Explain what you are wanting to do, and why. That way, we know what youre wanting and then can give ideashow safe would it be to put a set of coilovers there?
....... and ditching the leaf springs.
im getting the idea, you cant weld or fabricate. Adding a coilover mount kit to the vehicle is a very easy thing and it is 100% made to do what youre needing.Why not just do it right?
I actually do know how to weld and fabricate, I helped my stepdad with both of his that we made and welded... Though my perception isn't the best. At times I overlook the simplest things. I didn't realize that the lower mount was connected to the leaf spring and not the axel even though this will be my third time doing this. Seeing that now makes my initial statement neededim getting the idea, you cant weld or fabricate.
