Picked up the truck 4/13.
Plans are to fix it up and daily it while I gather parts for LS swap. Plans are a H/C 5.3 bored to 5.7 or a 6.0 bored .030. I have a set of 243’s that are off getting CNC work done and oversized stainless valves.
Transmission will be an AR5 which I scored one this week for $100 from the local marketplace. Living near Barksdale Air Force base you tend to get parts when guys are given orders to a different base and they are cleaning out their garage. Fab5 kit will get ordered soon with the stage 3 clutch (doesn’t look like a puck style)
Debating on running Holley or some other stand-alone system.
Had it detailed and the windows tinted after fixing the A/C
The good:
Got a great deal.
23.8mpg the only 2 ta
Straight body (maybe only 3 dents total)
Strong engine
Good mileage even if the o2 sensor is bad and seized in the manifold.
Cons:
A/C needed recharge and found the hose assembly needed replacing (fixed day 3)
Exhaust leak and the o2 sensor is stuck in the manifold. (Ordered a header to fix the leak. Cheapo for $109 from DNA.)
Door panels were loose and passenger door lock cylinder was pushed out the handle (easy fix with new panel push pins.
bed was missing a bolt (fixed day 3)
Need new tailgate side hinges. They are extremely loose.
dash bezel broken
Headlights broken on the backside (ordered need set)
Grille old and distorted (new unit ordered)
Have new o2 sensor and gonna swap the spark plugs when I install the header in the next week
The good:
Got a great deal.
Strong engine
Cons:
dash bezel broken
