Alright, I swapped the cluster out in my 98 S10 for a tach cluster, my problem is when the key is at ACC the odemeter works, but when its at run the odometer is turned off, also while driving, everyonce in a while all the warning lights will blink, they will blink with about .5-1 second intervals. Then go away for say 5-10 minutes, then return. The gauges all stay at the same position, and they all work perfectly fine.
Anyone have any ideas? Its pretty annoying, especially at night.
Premium Member
did you get another cluster from a 98. Aparently you have to specifically swap a 98 for a 98. That could be a cause.
No Regrets
yep the wiring in the 98 is different than the 99 and the 00+.
98's have to use a 98 cluster
99's have to use a 99 cluster
00+ can use any cluster from a 00+
Anyone know where a date code would be on this thing? You would think that if it was different it wouldn't work at all, but it all works perfectly fine, minus the odometer lighting up and the flashing warning lights.
