1 - 2 of 2 Posts
Cleaning out my garage. Email me for pictures / info. Located in Denville NJ. [email protected]
The following items for sale:
S10 cover: $125. Gray. Block-it Fabric (I think it is Block-it Noah - see link)
(http://www.covercraft.com/cartlink/index.php?cust_id=covercraft&prod_id=ccnh#cl-tab-customize)
Gauges:
Ractive blue carbn fiber tachometer. Housing painted white. Used. $50. (http://www.autotoys.com/x/product.php?productid=3882)
Ractive Blue Caron Turbo Gauge: $40. New in box.
Ractive Blue Carbon Oil Temp: Opened but never installed. $40.
Ractive 10 select LED air fuel ratio: Opened but never installed. $40.
36" x 18" SFC moonroof with gaskets. $80.
Cavilear 2.2l intake manifold. Painted custom blue with metallic flakes: $50. (paint peeling on underside.
Grover dual chrome truck horn: $50.
Accel coil packs for 2.2l s10. Used for less than 100 miles. $40 for pair.
2000 S10 2wd inner tie rod $25 for both.
56mm throttle body from quad 4: Painted black. $50.
Tools:
Used: Snap on Set, Socket, Metric, Semi Deep, 6-Point (12pc) (8 to 19 mm). (https://store.snapon.com/Deep-mm-Se...10-to-27mm-29mm-30mm-32-to-36mm--P646584.aspx) $350.
Used: Snap-on 10pc 12-Pt Flank Drive® Plus Metric Ratcheting Box/Open End Combination Wrench Set (10–19mm) (https://store.snapon.com/Ratcheting...-Combination-Wrench-Set-10-19mm--P644261.aspx) $150.
Used: Snap on Puller, Power Steering and Alternator Pulley: (https://store.snapon.com/Power-Stee...r-Steering-and-Alternator-Pulley-P635351.aspx). $35.
Craftsman impact gun. 300 ft-lbs: $50. Used.
Husky impact gun: 260 ft-lbs. $40. Used.
1 - 2 of 2 Posts
