This question is related to the following project.
Tire Wheel Automotive tire Motor vehicle Vehicle
Tire Wheel Vehicle Automotive tire Automotive lighting
Tire Wheel Automotive tire Motor vehicle Tread
Automotive lighting Automotive tire Hood Motor vehicle Bumper
Gas Tints and shades Wood Bumper Metal
Road surface Asphalt Wood Tints and shades Bumper
Do you have any suggestions for sealing the bulkhead “connector” below the Cowl Drain Outlet on the R side for circa 1996 vehicles? I will call it a “connector” for simplicity. It is a very high water flow area, unfortunately. If I understand correctly, this connector was relocated to the firewall in one of the subsequent years, if not the very next model year. Probably a wise engineering decision.
I will explain factory installation as I understand it. The 2 – halves of the connector are split by a vertical seam into a left and right side. They apparently snap together, and were filled with a clear rubbery compound where the wires pass through. The top and bottom of the connector seam around the screw holes do not appear well to be sealed by any compound. The connector attaches to the cab with 2 – sheet metal screws. An ~¼” thick seal is sandwiched between the cab and connector. I appears to be sponge (foam) neoprene or similar. There was an additional, small piece of thin, butyl tape/ribbon applied to the cab over the top sheet metal screw hole. The top of the connector bedded in that. The top sheet metal screw also holds the plastic water deflector in place. The deflector is in no way sealed to anything; is a bit flimsy; but is well contoured to the body of the connector. Water entering into the top of the deflector will make contact with the side of the connector & neoprene seal. I actually am not certain what purpose it serves. Not shown is a weighted, rubber flap that covers the Cowl Drain Outlet; maybe to discourage vermin from entering.
The ¼” seal is compressed a bit, but not in terrible condition. What would you suggest for sealing this pass-through to the cab interior? I can source some butyl sealant to replace the small ribbon/tape I previously removed; screw the connector (w/ original seal) and deflector back in place; and replicate the original, factory solution. However, I do not want to remove all the front end sheet metal again to correct water intrusion to the Cab interior.
Thank you in advance for you suggestions.
· B4U Task Force
I may be interpreting your post wrong.
Long-term presence of moist debris in the Cowl Plenum behind the R Drain Outlet caused seam sealer failure and rust; allowing a pathway for water from the Cowl Plenum into the Cab interior. I have repaired that. All front end sheet metal was removed in support of that investigation and repair, and remains removed. I am not confident in the factory sealing solution for the “connector” passing into the Cab below the R Drain Outlet. I am asking for opinions on sealing that connector, whether it be simply returning to the factory condition or pursuing a different solution. I will reassemble the front end sheet metal after I have considered suggestions and implemented an appropriate solution. I have some ideas, but do not want to bias potential responders.
· Been there Done it
Have you considered the technique roofers use of putting a flashing of bent tin above the area of concern to deflect water over the potential leak. I'd RTV the flashing and pop rivet it to the cab above the connector and then apply seam sealer. It might not stop every drop, but I bet it'll deflect 90% of the water over and away from the connector. And of course re-silicone the connector. Just make sure you get all the old stuff off. Silicone doesn't stick to old silicone. That's why quality roofers use polyurethane sealants these days. If you have to repair urethane it will stick to clean old urethane. Just cut the old bead and apply the new.
oldeerslayer,
So, in very general terms, both you and GM attempted/suggest a similar solution where the “connector” was/is sealed to the cab, but backed up by flashing/deflector. Depending on execution, the flashing you describe would potentially be a better implementation of the second part of that solution GM attempted with the black, plastic deflector.
There is no silicone on the mating surface of the “connector”. The seal is ¼” thick, neoprene sponge (foam) sheet, or something similar, with adhesive backing on the “connector side only. Are you suggesting adding silicone between the existing, or replacement, neoprene seal and the cab?
· time to get cereal
GM put that bulkhead pass-through there because the computer was under the dashboard in '94 and for most models in '95. In '98 they removed it because all computers were under the hood. Pretty sure you are overthinking the seal situation. I've never seen one leaking into the cab there.
