1 - 20 of 39 Posts
· Been there Done it
How many of each color?
If you totally repaint one in another color, say Competition Yellow, is it still an SS?
Spoken like a true mechanic. I agree.
But to an SS aficionado? I'd expect a reply like,"If it ain't white, red, or black, it ain't a SS".
Doesn't really matter. Was just thinking out loud.
Reactions: chevymec
So close..but no cigar. There's no fog lamps.
Can you post a pic of the OEM fog lamps? Don't remember ever seeing them on the 94-97. Curious where they mount. One of my 99's has them, but that's a different front end. Do the 97's have a different headlamp switch like the 98 up? Or is it a separate switch?
What's weird on the later ones is all the trucks have the wiring at the switch in a small retainer and the wiring in the headlight harness, but no wiring in between unless the truck has fog lights. Surprised no one has invented and sells the under hood part.
· B4U Task Force
The h/l switch is a rocker switch with a separate rocker for the parking lights. 95-97. This is a 94-95...before the lowered suspension.
350705
· Premium Member
Bet those lights, the valance, the mounts, and the switch are all pretty scarce 30 years later.
I happened to get 2 new fog lights for 1 side because my housings were trash. Figured I could salvage the OE lamp brackets. They were hard to find new.
Sent from my SM-G975U using Tapatalk
· B4U Task Force
I have a set from an Xtreme. The problem I'm having is figuring out how to mount them since the valance is from a 98+, 4x4, and the hole are directly in front of the frame horns. Seems to me that someone found some adapter brackets for that kind of application...can't seem to find the thread.
Discussion Starter · #20 ·
Doesn't matter where it came from...it came from the factory with fog lights. Got a pic of the SPID sticker in the glove box?
I do
350754
You might wanna do your home work, cause not all of them came with fog lamps
1 - 20 of 39 Posts
