Chevy s10 bad steering
791 Views 7 Replies 5 Participants Last post by  Original_Owner_86
I just bought a 2000 s10 extended cab 2wd. I have been driving it for about 3 weeks now everything seemed fine then it started making a knocking noise sounds like it’s coming from the driver side suspension area (not motet Knocking) I hear it when I hit bumps in the road but it’s gotten worse now ver the last week or so. The steering was tight when I first started driving it now it seems to have gotten lose. Also pulls to the right pretty bad .Yesterday while driving home from work it about half way home it got really bad. The best way I can describe It felt like the wheels were going to fall off going 60 mph it was hard to keep it straight The knocking noise was worse as well. Any ideas I jacked it up and looked under it but did not see anything broke. Anyone else ever have this problem I have no idea what to do or where to start.
Check to be sure all the lug nuts on the wheels are tight. Then jack up one side at a time and see if you can move the wheels by pulling and pushing on the top of the tire. That will tell you if you have a loose wheel bearing. Should only have the tinyest bit of movement. While both wheels are still on the ground have someone else slowly turn the steering wheel back and forth while watching the steering linkage for movement before the tire starts to turn. You'll need to be laying on the ground in front of the truck to see what's happening. It should not be running while doing this. Have the person turning the steering wheel keep you informed as to how much they are turning the wheel. Watch the pitman arm on the steering box for how long it takes before it starts moving. Then look at each joint in the steering linkage for excessive play.
Or you can take it to an alignment shop and have a pro check it out. They shouldn't charge much or anything to tell you what needs to be fixed. Avoid dealerships and national chains like Firestone or Goodyear or Midas. They tend be over priced and not the kind of place to take a 20+ year old vehicle. Find a local independent shop with a good rep. After their evaluation you can decide whether to pay them or do it yourself.
Since you don't sound like an experienced auto repairman or women, steering and suspension aren't the best place to learn. If something fails not only are you at risk, but so is everyone else on the road. You will need the shop to do an alignment when finished whoever does the work.
I also would not drive it in it's present condition. Except maybe to carefully get it to a shop for a diagnosis before a wheel falls off.
Reactions: 1
That’s pretty much what a friend of mine said as well. I know a lil more about the Mechanic’s of a vehicle then most woman but definitely not enough in this area to be able to do it on my own. Lol. Thanks for the Suggestions.
possible control arm bushings, wheel bearings, the list could go on.. but like old said above, get it checked out, because we can only guess from here.
Reactions: 1
Check the bushings in the upper/lower control arms, check the shock mount bushings and the idler arm. You can also bring it to a shop where they can give you a free check up with it in the air so you don't get dirty YET lol
All the shops I called today want to charge me $80 to $150 just to look at it. But if I have them fix it then they wave that money. What shops will look at it for free?
you have a potentially dangerous situation on your hands. Without knowing if the noise is a simple piece, or life-threatening, are you willing to take that risk? 8-150 sounds like 2 hours of labor to properly look over your suspension. $150 sounds much better than a car crash if it is something serious.
Have you climbed under the car? Taken a look to see if there is any glaring issues?
Reactions: 1
It is what it is. You own an older vehicle that will need more maintenance and repairs than a new one. If in life you have not invested your time and money into acquiring the knowledge, skills and tools to repair a vehicle and a place to work on them, you must pay those who have.
Why should a mechanic waste time diagnosing a problem so someone can fix it themselves?
Ask around to find a shop that others trust. Ask local auto parts clerks who they'd trust. Or even your insurance agent. Ask the shop if they and their mechanics are ASE, or "Automotive Service Excellence" certified. Then check them out with the Better Business Bureau online. Google just the shop name and city. Search results might reveal some angry customers who got ripped off, or who praise the shop.
Do you have a friend or neighbor who works on vehicles? Ask them nicely for an opinion, maybe to take a quick look and where they might go to have it repaired. If they do, take them some cookies or something else as a token of appreciation after you've had it repaired. But don't impose on them to fix it.
