1 - 12 of 12 Posts
I'm probably drunk.
Truck is a 2000 Blazer, 4.3
OK, so my truck has a crack in the plastic part of the radiator. I want to replace it but I have to sneak around and do it in my parking garage at my condo. If they see me doing it they'll make me stop so I have to be stealthy and quick about it.
My question is, besides the new radiator, what do I need to do this? How much antifreeze/water mix will I need? Will I need any transmission fluid or oil due to any cooler lines leaking while unhooked? And what kinda tools do I need? Ratchet sizes and any other specialty tools?
Thanks guys! I really appreciate it. :cool:
Chip Chipperson
youll need 10mm socket for the shroud,pliers if your hoses have the squezze clamps,they make a speciel tool for the trans lines but i just used to use a little flat head screw driver or pick,just make sure to not lose the clips,they are a pain to find at parts stores sometimesif they have them where you are getting the rad. i would go ahead and get some just in case,i would also check the hoses to see if they need to be replaced and i think that might be it,thats all i needed on my truck,and of course something to catch the fluid in.as fo the coolant,i cant remember how much it takes,and the trans fluid you really dont lose alot,just get a quart,but usually it doesnt even show it being low after.
loco hombre
They're called e-clips I believe. I use a dentist pick to remove them and they come right off. They're somewhat similar to this: http://circlip.net/e-clip.html.
10mm socket to remove the fan shroud, screwdriver for the hose clamps, and possibly a crescent wrench to pull the oil cooler & transmission cooler fittings out. On my new radiator, I had to remove the fittings from the old one and re-use them. Just carefully used a crescent wrench to pop them out and in.
Chip Chipperson
i knew i was forgetting a few things,but yeah most new radiators dont come with the fittings,or atleast the ones i sell at my work dont.
UN-BANNED B!TCHES!!!!!
You can also go to a local rad shop and have one made to order... they're pretty simple affairs these days... I had a new one made last year, works great.
where's my chippy?
basicly everyone covered it, one thing though is make sure you have multiple buckets, one isnt going to be enough unless its over like 7 gallons and also find somewhere to dispose of the coolant, dont just bring it to a car wash then pull the drain plug wash your car then put the plug back with new radiator and fluid, someone by me did this
THE Registered User
It took about a week for my rad to get to me.
1 - 12 of 12 Posts
