What have you used to try to clean cats? did it work or not work?
I see Cataclean, Dura-lube cat cleaner, CRC 'guaranteed to pass', et al / etc... I have heard lacquer thinner mixed with gas in some ratio may clean a cat...
What is in cataclean?
So the vehicle in question is not an s10... on an s10 I would probably just replace the cats and be done since they are easy to get to and cheap enough...
but on some vehicles the cats are very difficult to get to, such as the vehicle in question. The vehicle in question throws p0420 and p0430 (cat below efficiency bank 1, cat below efficiency bank 2) and the cats have likely been poisoned a handful of times over the years because ignition problems are extremely hard to diagnose on the vehicle in question. with new ignition parts It is difficult to get it to run without missing when the motor is below 50 degrees and especially difficult with a cold motor in very cold weather. once it gets warmed up ever so slightly it runs fine. the downstream o2 sensors have been replaced with new oem sensors but the upstream sensors are the originals with 130k because they are so difficult to get to, like the cat.
i have new cats and upstream sensors ready to install but sadly its so much work to get to them and the risk of mucking something up and having the vehicle go down for an extended period necessitates the need to dump $25 mystery juice into the fuel tank with a wish and a prayer... just wondering which cat cleaners the fine folks here have tried
thanks
thanks
