the canister is about 3 1/2 inches wide and has three tube and is bolted with a u shaped bracket. it had 3 tubes or wires running in and then there a plastic outlet that will leak as soon as the engine is started and it will leak for about 10 minutes after the engine is off.
whats the canister? is it the vacume for the fuel pump?
what are the symptoms of oil pressure switch failure?
thanks in advance.
:thumbup:
thanks in advance.
:thumbup:
