My 2002 2WD was having some really strange starting and electrical issues over the last week. It would happen randomly with no pattern.
You could turn the key and the engine would turn like it wanted to start, if you gassed it it would start, then as soon as you let your foot off the gas it would just rev down and die.
Sometimes it would also start, run ok, until you put it in reverse or drive, then it would rev down to like 200RPM for a sec then sputter and die.
But usually you would get into it, turn the key, and the power would just cut off entirely, come back on after a few on its own, until you turned the key again.
Then I pulled this thing that was behind the rear view out of it and its had 0 issues since. The Check Engine light that was intermittent for the MAF sensor hasnt popped back up either. The battery is new and I tested the alternator, fine as well.
Anybody know exactly what this is? When it warms up outside I’d like to remove the wiring and whatever else is with it. I've heard aftermarket remote stuff can cause issues but wow.
Thanks
Thanks
