I have a 1995 ss10 4.3l v-6 cpi unit with balance shaft and i need a new camshaft , but i dont know the correct part number for this engine .
I find one from compcams (56-440-8) but i dont know if it´s correct.
Some months ago i bought one from crower , but it did not fit in this engine .
if anybody know any cam for this engine (crower, crane , compcams , edelbrock ...) Please help me !
Thanks !
Road Race/Auto X S10
What kind of cam are you looking for? I have the 266hr for computer controlled vehicles. The reason I'm selling it is becuase I decided to go with the 270AHR. You have to get your vavleguides machined to run it becuase of the lift.
Theres also a cam by crow, that everyones in luv with. I'm sure some has the part number. It doesnt have as much lift as the comp cams so you can run it on the stock heads.
Quicker than a Hummer!
how do you know you need a new one? did you find a worn lobe by measuring the lift? Its quite a bit of work to get to the cam!
Project: Sabriel
i thought the cam in a CPI was rather aggressive, stock? at least Crane told me their cam for CPI's wasnt as aggressive as the stock one.
i need a new cam because my engine broke one rod and bent the camshaft .
I´m looking for a performance cam , but for stock converter and stock heads.
Thanks
no problem , a little bit more agressive than stock it´s ok
