footbraker
My motor is a 350 w/ stock flattop pistons(4 valve reliefs). It has fresh 882 heads w/ 1.94/1.50 valves and gasket matched intake ports. I'm using an edelbrock performer intake and 1406 carb (jetted 12% richer than stock). The cam is a Crower 267 HDP (210/216 dur. and .444 lift). My cyl pressure with this cam is 150 psi. I was wondering if a larger cam (221 dur. and .465 lift) would improve my ET's even though I'll lose 15psi of cyl pressure?
Isnt the stock 350 cam about .420 lift? The cam you have know is the same lift as a stock Ford 302 H.O. motor. (not that it matters). The bigger duration will allow the vavles to stay open longer, and the more lift the further the valves will open...So I guess the answer would be yes, it will make more power. Will you be able to tell it in the drivers seat, probably not. Although I could be wrong, someone correct me if I am.
Bit
footbraker
I had a 224 dur and 465 lift cam in before and the bottom end was nonexistent. Cyl pressure also dropped to 120psi. I guess I'm more concerned about the relation between cyl pressure and performance.
With the heads and piston combo your running I'd figure you've got around 8/8.5 to 1 compression.Longer duration will kill the bottom end like you said it did.
Try calling comp cams their Extreme series has openings and closings that are supposed to help cylinder pressure.
I had the same problem years ago w/a comp magnum 292 cam,in a stock bottom end 350.Sounds like your following the same path I went down.
BTW,when I changed from a mld roller to a much bigger one I went from,220 cranking pressure to 190,and picked up over 1/2 a second.
footbraker
was the motor NA or NOS?
It picked up both NA and sprayed.
Dynamic compression,includes valve overlap,and duration.The number is usually in the 9 to 1 range(high compression race motor) or less,if I remember correctly.I had read some articles on this awhile back.
Static compression involves the piston at BDC vs.TDC.(what you see advertised)
The compression guage your using gives you a reading based on dynamic compression.You can't really tell the static compression with it.Too many variables cam,engine temp, air temp,starter cranking speed and the fact that rarely do 2 gauges read alike.
They make great tools for finding potential problems,ie drastic drop in all cylinders or more then 10% between them.
I try to check and log mine every couple of months to see if I've got something going south.
