Status
Not open for further replies.
What campers can I use on my 91 single cab short bed? What makes and models can I use that are compatible or atleast somewhat comparable. Or what measurements should I have before considering one. Any help would be appreciated
Just make sure the topper you get is from a first Gen truck. Newer truck beds aren't perfectly square, they are a little wider in the front then they are in the rear for aerodynamic reasons.
Length and width are good measurements to start with.
Sent from my ONE A2005 using Tapatalk
Pretty much. I would ask for measurements from the seller first if it's coming off of anything other than am s10
A ranger top will fit perfect but it is a little taller just to verify.
M easier twice.....spend once.
BTW...dead thread...closed.
Reactions: Primero
Status
