i have a 1999 2wd s10 and im wondering if i’ll need spacers to fit these and if so what size and any recommendations on some good cheap spacers? tire size i’m getting is 245/50/R18
what?Moved.
Moved to the appropriate forum...Wheels/Tires/Brakes.what?
i still don’t understand i just need a clear cut yes or no please idk much about all that
my bad i only saw the bottom half of the thread and got confusedClick on that link, it says his exact setup with the same wheels... how much more do you want?
sorry only saw the bottom half of the thread and got confused, so thank you!
Look on ebay for those wheels. They look like IROC wheels. You should be able to find them in a bolt pattern that fits S10's. So, you wouldn't need spacers or adapters. S10 bolt pattern is 5x4.75.i have a 1999 2wd s10 and im wondering if i’ll need spacers to fit these and if so what size and any recommendations on some good cheap spacers? tire size i’m getting is 245/50/R18
i don’t need adapters i want to know if i need spacers lolLook on ebay for those wheels. They look like IROC wheels. You should be able to find them in a bolt pattern that fits S10's. So, you wouldn't need spacers or adapters. S10 bolt pattern is 5x4.75.
1. i uploaded the pic of the wheel1. People are trying to help you.... but you have done little to provide info on the wheel you want.
2. Those wheels are 38mm offset, but the vehicle should have somewhere around ZERO offset or they will sit way under the truck (looking stupid) & possibly rub the suspension.
3. You say you do not need adapters but the bolt pattern is NOT correct... close does not count. Your bolt pattern is 120.65mm not 120mm.
Also wheel the center bore (66.9) will not fit over your hub (70.3), but it may work with the proper adapter and possibly some wheel grinding.
4. If you get a 1.5" spacer (that also CORRECTS the bolt pattern) it will be close to zero offset & will be close to the factory location... you should still measure & test fit to put them where you like the stance before you buy adapters. You may like them sticking out a little farther. (depending on the tire you run)
5. Also the tire you are looking at (a 245/50-18) is rather tall (27.7") for a 2WD, you may be better off with a 245/45 (26.7"), but this tire would be better suited for an 8" wide wheel.
6. All of this is why someone posted the IROC wheel (that looks remarkably close & I think you can get them in black), in the proper width & will not require an adapter.
You seem to have all of the answers....why are you bothering us?1. i uploaded the pic of the wheel
2. these replicas are 0 offset
3. plenty of people run them without adapters
4. that’s the simple answer i was looking for
5. someone recommended me that tire
6. yeah i know i saw it and if you read my replies you would know 👍🏻
If they are zero offset then you don't need spacers... so I'm not sure that's the simple answer you are looking for. Posting a picture and saying what do I need isn't the best way to get a correct answer.1. i uploaded the pic of the wheel
