Sweet Thanks!!!
Sweet Thanks!!!96 and 97 tracks are the same, so no modifications needed. It's literally as easy as changing 4 bolts :tup:
This is also the case for 94's no mods needed to get the 99 camaro seats in mine. Swap S10 tracks to Camaro seat bolt in and go.96 and 97 tracks are the same, so no modifications needed. It's literally as easy as changing 4 bolts :tup:
Camaro brackets aren't going to work in your truck. Use S10 tracks and go from there.Ive got a bench in a 2002 , but if I got racing seats with camaro brackets i can just modify the brackets there shouldnt be any other problems?
As others have stated. You need S10 tracks.Ive got a bench in a 2002 , but if I got racing seats with camaro brackets i can just modify the brackets there shouldnt be any other problems?
98+ brackets will work too wont they? but the rear right hole will not line up. I took 94-97 power Blazer seats and they bolted right up in my 98 s10 all but the rear right hole. I just left it empty and 3 out of the 4 was still plenty to keep the seats down tight and sturdy. I could drill out a hole and bolt it down still but I see no needYou will need either 60/40 brackets or bucket brackets. They have to be from a 94-97 though. Then the Camaro seats will bolt right on.
