1 - 12 of 12 Posts
<SEVERED TIES>
you should put bracing between the rails it helps prevent the bed from flexing and cracking the skin. square tubing works well i think the guy in the last picture probably welded sheetmetal over the bracing.
coreect i welded in a brace across the top and slide the skin over the top of it and the to bars a little bit farther down
is dekitted...
rollpan and tailgate molded together as one, no more functioning gate, just solid metal.....
1 - 12 of 12 Posts
