I have C5 Corvette rims (17x8.5 front and 18x9.5 rear) with 2 inch spacers on each wheel and the front tires rub at about 1.5 turns
It rubs on the sway bar and the frame on both sides closer to the front
· Premium Member
2" spacers do not provide enough room at all.
I use 2.5" spacers at all 4 corners. At times they do rub at full lock but it's tolerable. 2.75" will help more but tends to put the tire outside the well or right there at the lip so a decent bump or dip in the road may cause the tire to contact the fender
Tire Automotive parking light Wheel Vehicle Car
Reactions: Jaboc33
The second gens must be a little bit wider than the firsts. I might be able to get away with a 2.25 without it sticking out, or just barely sticking out
FWIW
I run a 2” spacer with ls1 brakes which give or take is about 2 5/16”. 18/19 C6 wheels. 2” might not be enough. I hear people have good luck with 2.25. 2.5 might be too much
· Premium Member
2.5 spacers x4 on my 02 Blazer w/ c6s
Wheel Tire Automotive parking light Car Land vehicle
· Premium Member
Some of the different spindles increase the track width too. Be mindful of that. Extra money spent on the hub centric nicer spacers/adaptor seems smart to me. Good luck sir.
