1 - 12 of 12 Posts
03 GMC Sonoma SLS & 04 Chevrolet Blazer Ls
I went through the C101 pigtail and found where every pin goes. The harness I use for tracing was out of a 2003 GMC Sonoma SLS 4.3l. PCM/P59 blue/green plugs. This PCM can be used for drive by cable or drive by wire swaps just needs to be reflashed. I matched up all pins and cross reference them with the wiring diagram from LT1 some of the pins in his pinout say not used but I think when he did the pinout he wasn't thinking about the A/C controls or Cruise control. But some of us will use them. hope this helps.
Rectangle Font Parallel Pattern Paper
Pin 10 green plug. engine speed signal.
Pin 17 green plug. AC high pressure signal input.
Pin 33 Blue plug. TCC brake switch / cruise control release switch signal.
Pin 49 green plug. vehicle speed signal.
Pin 75 blue plug. off / run/crank voltage.
Pin 50 green plug. Vehicle speed signal.
Pin 35 blue plug. CPP switch signal (M/T).
Pin 13 green plug. Cruise control engagement signal.
Pin 59 blue plug. Class 2 serial data.
· Been there Done it
The transmission range switch is the same on both 4L60E and 4L80E transmissions.
When the time comes to go 4L80E:
If you open these in a new tab they get bigger.
The 4L80E doesn't have the 3-2 downshift solenoid.
IDK what my note about the "not installed yet" was all about. Been over a year ago.
Font Material property Parallel Symmetry Pattern
Product Font Rectangle Parallel Slope
Camera Camera lens Motor vehicle Reflex camera Digital camera
I found the male plug that will plug into the factory cruise control female plug on the firewall if you do not want to cut your harness.
GM drive by wire TAC module cruise control wiring.
This male automotive connector will plug in to your factory cruise control connector.
Cruise control male plug
Automotive tire Camera accessory Bumper Rectangle Auto part
Part Numbers
10 Position Automotive Connector P/N 12045808 Qty-1 $1.38 Each
Terminal Position Assurance Automotive Connector P/N 12124264 Qty-1 $0.29 Each
Terminals Automotive Connector P/N 12045773-L Qty-6 $0.29 Each
Cavity Plug Automotive Connector P/N 12059168 Qty-6 $0.12 Each
Wire Seal Automotive Connector P/N 15324973 Qty-6 $0.10 Each
And you can get all of them here > https://www.mouser.com/
Automotive lighting Rectangle Musical instrument accessory Nickel Bumper
Gas Circuit component Electric blue Wire Cable
Tool Needed for Terminals. Weather Pack Crimper Tools for Delphi.
https://www.amazon.com/gp/product/B071KFLY43/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Rectangle Slope Schematic Font Parallel
You can buy the connectors and pins
Just put the part number in the search box and if it is available it will show up. On that connectors page will be a data sheet, click on it to find out what comes with the connector and what pins are needed.
This is the engine pin outs for a 2005 Chevy Sierra with a 4.8, 5.3 or 6.0
Accelerator Pedal Position (APP) Sensor
not available on the mouser site?
Product Font Rectangle Art Gas
Connector Part Information • 15318071
• 10-Way F Metri-Pack 150 Series (GY)
Pin Wire Color Circuit No. Function
A-----------GY--------------------1273------------Low Reference
B-----------PU--------------------1272------------Low Reference
C----------L-BU-------------------1162---------APP Sensor 2 Signal
D-----------TN--------------------1274----------5-Volt Reference
E-----------BN--------------------1271------------Low Reference
F----------D-BU-------------------1161---------APP Sensor 1 Signal
G--------WH/BK-------------------1164----------5-Volt Reference
H-----------------------------------------------------Not Used
J---------YE/BK-------------------1275-----------5-Volt Reference
K---------D-GN-------------------1163-----------APP Sensor 3 Signal
Camshaft Position (CMP) Sensor
Office equipment Office supplies Font Automotive design Cylinder
You have to click the related parts tab to see the pins, seals, and mating connector
Connector Part Information • 12059595
• 3-Way F Metri-Pack 150 Series (BK)
A-----------BN/WH---------------633--------CMP Sensor Signal
B------------PK/BK---------------632---------Low Reference
C-------------RD------------------631--------12-Volt Reference
Crankshaft Position (CKP) Sensor
Product Font Water Material property Office equipment
onnector Part Information • 15324165
• 3-Way F Metri-Pack 150 Series (WH)
A---------D-BU/WH---------------1869---------CKP Sensor Signal
B-----------YE/BK-----------------1868----------Low Reference
C------------L-GN-----------------1867--------12-Volt Reference
Engine Coolant Temperature (ECT) Sensor
Gesture Font Cylinder Gas Parallel
Connector Part Information • 15336024
• 2-Way F GT 150 Series, Sealed (BK)
1-------------BK------------------407------------Low Reference
2-------------YE------------------410------------ECT Sensor Signal
Evaporative Emission (EVAP) Canister Purge Solenoid
Product Font Engineering Auto part Cylinder
Connector Part Information • 12124037
• 2-Way F Metri-Pack 150 Series (BK)
A------------PK-------------------439----------Ignition 1 Voltage
B--------D-GN/WH---------------428-----------EVAP Canister Purge Solenoid Control
Evaporative Emission (EVAP) Canister Vent Solenoid
Font Technology Engineering Parallel Technical drawing
Connector Part Information • 12052643
• 2-Way F Metri-Pack 150 Series, Sealed (RD)
A------------WH------------------1310------------EVAP Canister Vent Solenoid Control
B------------OG------------------2640------------Battery Positive Voltage
Fuel Composition Sensor (w/L59)
Product Automotive design Font Line Auto part
Connector Part Information • 12146121
• 3-Way F Metri-Pack 150 Series, Sealed (BN)
A------------WH------------------1579-------Fuel Temperature/Composition Signal
B-------------PK-------------------439--------Ignition 1 Voltage
C ------------BK-------------------550--------Ground
Fuel Injector 1 (Except L59)
Automotive tire Rectangle Automotive lighting Automotive design Automotive exterior
Connector Part Information • 15411634
• 2-Way F Micro-Pack 064 Series (GY)
A------------PK------------------1039----------Ignition 1 Voltage
B------------BK------------------1744----------Fuel Injector 1 Control
Fuel Injector 1 (w/L59)
Font Parallel Drawing Toy Rectangle
onnector Part Information • 15305086
A-------------PK-----------------1039-----------Ignition 1 Voltage
B-------------BK-----------------1744---------Fuel Injector 1 Control
Fuel Injector 2 (Except L59)
Automotive lighting Automotive tire Automotive design Rectangle Automotive exterior
A-------------PK------------------1239---------Ignition 1 Voltage
B---------L-GN/BK---------------1745-------Fuel Injector 2 Control
Fuel Injector 2 (w/L59)
Toy Rectangle Font Parallel Drawing
A-------------PK------------------1239----------Ignition 1 Voltage
B--------L-GN/BK----------------1745---------Fuel Injector 2 Control
Fuel Injector 3 (Except L59)
Rectangle Automotive tire Automotive lighting Automotive exterior Automotive design
B----------PK/BK----------------1746--------Fuel Injector 3 Control
Fuel Injector 3 (w/L59)
Toy Font Rectangle Parallel Drawing
A------------PK-------------------1039---------Ignition 1 Voltage
B----------PK/BK-----------------1746--------Fuel Injector 3 Control
Fuel Injector 4 (Except L59)
Automotive lighting Rectangle Automotive design Automotive exterior Automotive tire
B---------L-BU/BK----------------844--------Fuel Injector 4 Control
Fuel Injector 4 (w/L59)
Rectangle Font Toy Parallel Drawing
Connector Part Information • 15305086
A-------------PK------------------1239-----------Ignition 1 Voltage
B-----------BU/BK-----------------844-----------Fuel Injector 4 Control
Fuel Injector 5 (Except L59)
Automotive lighting Automotive tire Rectangle Automotive exterior Automotive design
B----------BK/WH----------------845---------Fuel Injector 5 Control
Fuel Injector 5 (w/L59)
Font Parallel Rectangle Drawing Line art
B-----------BK/WH---------------845-----------Fuel Injector 5 Control
Fuel Tank Pressure (FTP) Sensor
Font Automotive design Auto part Office equipment Drawing
A-------------BK------------------470------------Low Reference
B-----------D-GN-----------------890---------Fuel Tank Pressure Sensor Signal
C------------GY-------------------474---------5-Volt Reference
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 (L59/LM7)
Gesture Automotive exterior Font Engineering Auto part
onnector Part Information • 12176897
• 4-Way F Metri-Pack 150 Series, Sealed (GY)
A-------------TN-----------------1664---------HO2S Low Signal Bank 1 Sensor 1
B-----------PU/WH--------------1665---------HO2S High Signal Bank 1 Sensor 1
C-----------BK/WH--------------3113---------HO2S Heater Low Control Bank 1 Sensor 1
D-------------PK-----------------539-----------------Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 (LR4)
Product Gesture Font Sharing Parallel
Connector Part Information • 15326423
A-------------TN------------------1664---------HO2S Low Signal Bank 1 Sensor 1
B-----------PU/WH---------------1665---------HO2S High Signal Bank 1 Sensor 1
C-----------BK/WH---------------3113---------HO2S Heater Low Control Bank 1 Sensor 1
D-------------PK-------------------539--------------Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 (LQ4)
Product Font Auto part Gas Parallel
onnector Part Information • 12092839
• 4-Way M Metri-Pack 150 Series (BK)
D-------------PK------------------539--------------Ignition 1 Voltage
E-----------BK/WH---------------3113--------HO2S Heater Low Control Bank 1 Sensor 1
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 (L59/LM7)
Gesture Font Automotive exterior Engineering Auto part
Connector Part Information • 12160482
A-----------TN/WH--------------1669---------HO2S Low Signal Bank 1 Sensor 2
B-----------PU/WH--------------1668---------HO2S High Signal Bank 1 Sensor 2
C-------------BN-----------------2391---------HO2S Heater Low Control Bank 1 Sensor 2
D-------------PK-----------------1539---------------Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 (LR4/LQ4)
Product Gesture Font Gas Sharing
A----------TN/WH----------------1669---------HO2S Low Signal Bank 1 Sensor 2
B----------PU/WH----------------1668---------HO2S High Signal Bank 1 Sensor 2
C------------BN-------------------2391---------HO2S Heater Low Control Bank 1 Sensor 2
D------------PK-------------------1539---------------Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) Bank 2 Sensor 1 (L59/LM7)
Gesture Font Engineering Auto part Automotive exterior
Connector Part Information • 12176897
• 4-Way F Metri-Pack 150 Series (GY)
A-------------TN----------------1667------------HO2S Low Signal Bank 2 Sensor 1
B-------------PU----------------1666------------HO2S High Signal Bank 2 Sensor 1
C------------L-GN--------------3212-------------HO2S Heater Low Control Bank 2 Sensor 1
D-------------PK-----------------539-------------Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) Bank 2 Sensor 1 (LR4)
White Product Gesture Font Sharing
A------------TN------------------1667----------HO2S Low Signal Bank 2 Sensor 1
B------------PU------------------1666----------HO2S High Signal Bank 2 Sensor 1
C----------L-GN-----------------3212-----------HO2S Heater Low Control Bank 2 Sensor 1
D------------PK------------------539------------Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) Bank 2 Sensor 1 (LQ4)
Font Auto part Circle Parallel Drawing
Connector Part Information • 12092839
• 4-Way F Metri-Pack 150 Series (BK)
A-------------TN-----------------1667-----------HO2S Low Signal Bank 2 Sensor 1
B-------------PU-----------------1666-----------HO2S High Signal Bank 2 Sensor 1
D-------------PK------------------539---------------Ignition 1 Voltage
E------------L-GN----------------3212-----------HO2S Heater Low Control Bank 2 Sensor 1
Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 (L59/LM7)
A-------------TN------------------1671--------HO2S Low Signal Bank 2 Sensor 2
B-------------PU------------------1670--------HO2S High Signal Bank 2 Sensor 2
C-----------RD/WH---------------3223--------HO2S Heater Low Control Bank 2 Sensor 2
D-------------PK------------------1539--------------Ignition 1 Voltage
Discussion Starter · #8 · (Edited)
Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 (LR4/LQ4)
White Gesture Font Automotive lighting Art
A-------------TN-----------------1671---------HO2S Low Signal Bank 2 Sensor 2
B-------------PU-----------------1670---------HO2S High Signal Bank 2 Sensor 2
C----------RD/WH---------------3223---------HO2S Heater Low Control Bank 2 Sensor 2
D-------------PK-----------------1539-----------------Ignition 1 Voltage
Ignition Coil 1
Parallel Technology Font Engineering Diagram
Connector Part Information • 15413116
• 4-Way F GT 150 Series, Sealed (GY)
A-------------BK------------------550---------------Ground
B-------------BN-----------------2129-----------Low Reference
C-------------PU------------------2121-----------IC 1-8 Control
D-------------PK------------------1039----------Ignition 1 Voltage
Intake Air Temperature (IAT)/Mass Air Flow (MAF) Sensor
Office equipment Gesture Rectangle Automotive design Office supplies
Connector Part Information • 15305555
• 5-Way F Metri-Pack 150 Series (BK)
A-------------BK-------------------552----------Low Reference
B-------------TN-------------------472--------IAT Sensor Signal
C-----------BK/WH----------------451--------------Ground
D-------------PK-------------------439---------Ignition 1 Voltage
E-------------YE-------------------492---------MAF Sensor Signal
Knock Sensor (KS) - 1 & 2
Eye White Font Art Circle
Connector Part Information • 12103023
• 1-Way TRW (GY)
A-----------D-BU-----------------496----------Knock Sensor 1 Signal
A-----------L-BU-----------------1876---------Knock Sensor 2 Signal
Manifold Absolute Pressure (MAP) Sensor
Font Engineering Auto part Drawing Technical drawing
Connector Part Information • 12129946
• 3-Way F Metri-Pack 150 Series (GY)
A-----------OG/BK---------------469-----------Low Reference
B------------L-GN----------------432---------MAP Sensor Signal
C-------------GY------------------597---------5-Volt Reference
Throttle Actuator Control (TAC) Module C1
Musical instrument Rectangle Line Office equipment Font
Connector Part Information • 12191065
• 16-Way F Micro-Pack 100 Series (GY)
1 D-GN 485 TP Sensor 1 Signal
2 GY 416 5-Volt Reference
3 BK 452 Low Reference
4 D-BU 84 Cruise Control Set/Coast Switch Signal
5 GY/BK 87 Cruise Control Resume/Accel Switch Signal
6 L-BU 1320 CHMSL Supply Voltage
7 PK 1339 Ignition 1 Voltage
8 BN 582 TAC Motor Control - 2
9 L-BU/BK 1688 5-Volt Reference
10 BK/WH 1704 Low Reference
11 PU 486 TP Sensor 2 Signal
12 OG/BK 1061 UART Serial Data
13 D-BU/WH 774 UART Serial Data
14 GY 397 Cruise Control On Switch Signal
15 BK 550 Ground
16 YE 581 TAC Motor Control - 1
Throttle Actuator Control (TAC) Module C2
Rectangle Font Gas Line art Design
Connector Part Information • 12177081
• 10-Way F Metri-Pack 150 Series (BK)
A GY 1273 Low Reference
B PU 1272 Low Reference
C L-BU 1162 APP Sensor 2 Signal
D TN 1274 5-Volt Reference
E YE/BK 1275 5-Volt Reference
F D-BU 1161 APP Sensor 1 Signal
G WH/BK 1164 5-Volt Reference
H Not Used
J BN 1271 Low Reference
K D-GN 1163 APP Sensor 3 Signal
Throttle Body
Font Line Engineering Auto part Technology
onnector Part Information • 15326836
• 8-Way F GT 150 Series, Sealed (BK)
A YE 581 TAC Motor Control - 1
B BK/WH 1704 Low Reference
C BN 582 TAC Motor Control - 2
D BK 452 Low Reference
E L-BU/BK 1688 5-Volt Reference
F PU 486 TP Sensor 2 Signal
G D-GN 485 TP Sensor 1 Signal
H GY 416 5-Volt Reference
Transmission Range Switch Connector, Wiring Harness Side
Office supplies Office equipment Typewriter Musical instrument Font
Connector Part Information • 15416722 BLK
• ASM Conn 12 F GT
There is two types of pins for this transmission plug. 280 series for pins 1&12 P/N 15304720-L and 150 series for 2-11 pins P/N 15304720-L.
1 DK GRN 1433 Clutch Start Switch Signal
2-3 -- -- Not Used
4 YEL 772 Transmission Range Switch Signal B
5 BLK/WHT 771 Transmission Range Switch Signal A
6 GRY 773 Transmission Range Switch Signal C
7 BLK/WHT 451 Ground
8 WHT 776 Transmission Range Switch Signal P
9 LT GRN 275 Park Neutral Position Switch Signal
10 GRY 1524 Back-Up Lamp Supply Voltage
11 PNK 839 Ignition 1 Voltage
12 PPL 639 Ignition 1 Voltage
Discussion Starter · #9 ·
Discussion Starter · #10 ·
ACDelco Flex Fuel Sensor Plug
Automotive lighting Rectangle Purple Bumper Gadget
Plug 15326808
Pins 12191818
Lock 15317832
Seals 15366021
ACDelco 13507128
Trigger Gun barrel Camera accessory Gun accessory Air gun
Discussion Starter · #11 ·
C1-C2-C3-C4
Rectangle Font Gas Symmetry Electronic device
Connector Pin Part Information
Pins 20 AWG to 17 AWG Terminal P/N 12077411-L
Pins 18 AWG to 17 AWG Terminal P/N 12110844-L
Pins 14 AWG to 12 AWG Terminal P/N 12110842-L
1 - 12 of 12 Posts
