1 - 1 of 1 Posts
I have a 98 s10 2.2 5 speed manual with about 275K. Starts right up and runs strong.
Yesterday on my way home when I have it in gear and press the clutch in I hear an electrical buzzing sound ( just like a relay sound ) coming from the transmission and all of the indicator lights flash on the dash just the same as when you start it up. Its only at the very beginning of the clutch pedal while it is pressing/releasing the neutral switch. It sounds as if a relay cant tell if it wants to be on or off and just clicks back and forth quickly
I ordered a new switch and hopefully that is the cause. Is there something else that would be causing this?
1 - 1 of 1 Posts
