I have a '98 S-10, with a 5 speed and 2.2. Lately the truck bucks- like it was in the wrong gear - at certain rpms (1700-2500). It doesn't matter if the truck is accelerating or decelerating. It doesn't matter what speed or gear either. I changed the plugs and wires. I tested the volts on the MAP and TPS sensors and both are out of spec. I think it could be the PCM. Anyone have this problem and if so, was it the computer? Any insight would be appreciated.
Low and Slow
I'd really like to know the answer to this question also. Mine does the exact same thing, and I was thinking it was maybe the plugs also. But if you say it didn't help anything, I don't have to do it. Any ideas would be appreciated...
yeah I replaced the plugs and wires, ran a multimeter on the coil pack and everything checked out voltage wise, but the the buck was still there. I also ran the multimeter on the TPS and MAP sensors and got bad readings (it should be .5 volts on each sensor with the engine off and ignition on I think). This means either a wiring prollem or a PCM prollem. I doubt it's wiring b/c it's both sensors. I get no SES light either (which is odd). A bad TPS will cause bucking. Just for sh%ts and grins why don't you run a meter on each of those sensors and see what you get. I am prolly gonna buy the comp. I read somewhere on the web that stock comps go bad. $85 refurbished.
