Well, going down the road....driving normally, all of a sudden go to shift from third to 4th, clutch goes down normal, and when I move the shifter....its stuck it seems, well, turns out the clutch is completely out, I put all my weight on the clutch basically standing on the clutch and it finally comes disengaged, but obviously I did something, either the throwout bearing or the pressure plate.....so while its all apart, I'm upgrading....
Centerforce stage 1 clutch/pressure plate/throwout bearing......
or any other suggestions, but this sucks....I knew something was up when I first bought and the clutch would go to the floor, I thought I had the problem fixed when I started filling up the clutch fluid resevoir, but I think the damn pressure plate was leaking or something and sucking that clutch fluid through, or something like that........damnit
Caleb
Caleb
