:banghead:
Just wondering if anyone could help me out here...
OK GOTTA 1990 S-10...... My brake petal can now compress to the floor... the brakes still work though. no leaks no loss of fluid.. wondering if theres an electronic brake booster? or what the deal is? the brakes work but only when I press it all the way to the floor and its only in the last tiny bit that I get use of the brake.
Anyone else have a similar problem? or know how to fix? Gimme your ideas...:wtf:
N
Guest
minytrker said:
If you have power brakes then you have a bad power booster or a vac leak.
Yea thats my guess.
Turn your truck on and let it idle for a few seconds and then turn it off and press the brake and see if u can hear air rushing out when u press down on it.
N
Guest
Well thats normal for it to get hard cause u are loosing vacume.
Have u tried bleeding your brakes. Try it anyway just to see what it does. Remember to start at the wheel farthest from the master cylinder and make sure it doesn't get empty.
