2004 ZR5 crew cab. No brakes except for a small little bit when running (not enough to safely drive). Replace Master Cylinder and bench bled it twice. Bled lines in order, back to front with a helper. Didn’t resolve issue. Reversed bled twice, that didn’t change anything either. It appears that what little brake I have is on the rears, not the front. Vacuum appears to be working well and I can’t find any leaks. I’m open to ideas because I’m stumped.
The abs may be your issue...need to activate the solenoids...might take a Tech II.
BTW...a 2004 is a 2nd gen, and this has been moved to Wheels/Tires/Brakes.
Reactions: Obeone2
Registered Hoosier
Did you do some brake reapirs, or just jumped in and brake pedal to the floor?
Perhaps wheel cylinders?
All were replaced over a month ago. I’m thinking it’s something to do with the ABS system. I can’t get it into a garage until the 25th so I’m in limbo until then unless I can figure out the problem.
