1 - 2 of 2 Posts
I have an '01 xtreme with discs up front and drums in the rear. Are there break wear indicators installed on them? If so do both the discs and drums have them? And what type of noise do they make when they need replacement? Thanks for the help
Never seen a wear indicator on rear drums. except for the noise of rivits draging on the drum. Kinda sickining. The discs have little metal tabs that hit the rotor before the brakes are completely worn out. At least that is what happens if they were not bent out of the way when installed. Any way you will hear the front wheels screech but the screech will stop when you apply the brakes.
1 - 2 of 2 Posts
