xtreme nutcase
i just installed a set of hawk performance pads 3 weeks ago. i got it from a high performance shop. problem is the pads are starting to squeal just slightly. it's not too loud, but it's noticeable.
i've checked the calipers, and i dont see anything wrong mechanically. could it be the pads? could it be contaminated somehow. i used brake cleaner generously when i installed it. do you guys know if i can buy anything to apply to the pads to quiet it down a bit?
i would a ppreciate any answers.....:) :) :)
Say lowered d
With high
performance pads, they are going to squeak. It just has to suck:bash:
T/A drivin foundin member
shave the pads if they arent already,
___________ ___________
[___________] /_____________\
unshaved shaved
xtreme nutcase
Re: stop that squeak
rick said:
Get you some copper grease and coat the backs of the pads as well as the edges and put them back on.I bet it will stop that noise!
so you figure the noise is caused by the backing plate rubbing in to the caliper? i thought it's the pad material rubbing against the rotors that's making the noise.
i'll try it this weekend and hope it works.
thanks.....
Camaro Owner, S10 Lover.
Any performance bad is going to make some squeeling noise. Depends on the type of pads but im 99.9% sure they are semi-metallic breakpads. They will make noise because they have a higer volume of metal in the pad, hence, metal to metal equals noise! Like someone mentioned above, get that "lube" for them, it should either go away, or not be as loud.
If you cant bear it take the pads back "under warranty". Then, buy yourself a nice set of ORGANIC performance brake pads. No noise, or brake dust (very good for custom rims). Only bad thing is they wear fairly quickly. (15-20K range, my driving 10-15)
