so since i retook my ole s10 its got this problem where the parking light portion of my brake lights stay on regardless of the switches being on or off and wether the truck is on or off...if i depress the brakes they will not light up, if i turn on the hazards they dont blink...i reattached what appeared to be a ground wire to the frame where the truck harness connects to the bed harness, and nothing, still the same thing...any ideas what this coudl be? brake switch maybe?
So the parking lights in the rear never turn off at all? I know I had an issue not too long ago similar to this. Turned out since the bulbs are double filaments one was bad, and made it do a bunch of crazy things. Check all your bulbs make sure that both filaments light up.
bad bulbs can give funky relusts but not likely to keep the lights on,
pull the flashers, check switches, burnt/shorted wiring or for bad rewiring job
found it to be the brake light switch afterall..the plastic threads were all stripped out and wasnt even contacting the pedal..but thanks for the ideas
