Hello,
You guys have helped me out alot with this 83' truck, thanks a lot. I got all the way home and the brakes quit working...I bought a new gasket for master cylinder resivoir and topped it off. The brakes still felt extremely squishy, so I figure I'll bleed them. Upon removing the wheel and about to bleed the front caliper I notice the brake hose has a big tear in it, so I ordered a set of Stainless Steel brake lines along with speed bleeders from LMC Truck.
Will I need any special tools to remove the lines? I have had to buy copper washers that install on the caliper where the hose meets it because they can only be used once, is that the case with these s10's as well?
Thanks again,
CD
Thanks again,
CD
