Normal...WTF is normal ?
Is it normal to push down on the sealed brake fluid (metal) cap w/ no wear/age rubber seal & hear air escaping then re-entering the housing
(at rear) where the rubber underside snap's to the plastic housing.
I was thinking the assembly is supposed to be air tight, but there I go thinking again...
Discussion Starter · #2 ·
I didnt think this question was a stumper...
It should be sealed. Brake fluid is hygroscopic. Kinda weird it does that...
Wait...I figured it out. You should have a plastic cap and underneath should be a large rubber diaphragm that seals to the cap. That diaphragm extends as the fluid is pushed into the lines. It helps the fluid to return to the reserviour. It needs a small airway to allow air in between it and the cap.
So if your diaphragm is good then I wouldn't worry about it.
Discussion Starter · #5 · (Edited)
Yeah, mines actually a metal cap/rubber diaphram & when you push down on the middle it sounds like (very little) air is pushing out/retracting back in a small spot at the very back center of the cap
