FULL THROTTLE
Will Z06 Brakes fit on my 01 S10 4.3? I know there are brackets to put them on a LS1 Camaro, but will they fit my truck?
Canyon Carver
Either PM or do a search on a member who's name is "Samdogmx". He used a set-up to allow him to run 4th gen Camaro brakes in the front on his. If there are brackets to make the Z06's brakes fit on Camaro's then I guess they could be used with a little fab work.
He would probably be the best person to point you in the right direction.
It would take quite a bit of custom machine work. Your current caliper bracket is cast into the steering knuckle as one piece, unlike the Corvette and Camaro.
FULL THROTTLE
That could create some problems, maybe i'll just stick with my SSBC Upgrade for front and rear next year.
