1 - 10 of 10 Posts
Drag it or Park it
well im getting ready to bag the rear of my truck and im using a sd bolt in c notch how exactley do i go about installing it? and im also gonna be running a 7 gallon tank w/ 4 valves, im mounting the valves on the tank , so when i run the air line off of the valves would i use a "T" fitting to run the line to each bag?, im only doing FB not FBSS. then do the same for the front?
Drag it or Park it
ok thats what i figured. have any idea about the notch? i would just use the sd step notch but my parents said i cant cut the frame anymore until its payed off so w/ the bolt in i can cut it and they wont notice it.
former owner
Austin, you got check valves to prevent side to side air transfer?
If not, have fun with that body roll.
Mike D.
yea my truck has independent fronts and i still get some roll, i can't imagine it t'd off
Drag it or Park it
ya i know i was thinking about that today, i was just gonna do it b/c it is cheaper since i already ave 4 valves, but it may be worth it to spend the extra $$$ on 4 more valves
former owner
Yeah, because the cost of the check valves isn't going to save you all that much money. You'll be glad you went with independent control later.
fl member
Or just run 4 valves in front and 2 in back. you dont really notice the air transfer of the bags in the back
Drag it or Park it
Discussion Starter · #10 ·
ya im just gonna run 8
1 - 10 of 10 Posts
