1 - 2 of 2 Posts
I recently purchased a 94 2dr Blazer 4x4. I did multiple searches on different lifts and such, and I see there isn't really a whole lot out there for the old style Blazers. I see they have a 2 and a 3 inch body lift kits avaliable. I can install the kit with out a problem, I am a technician at a local chevy dealer, but my questions are.....
1. If I go with the 2 or 3 inch body lift, do i have to lengthen any of the wiring harnesses? Or will it be fine.
2. What size of tires could i go with, without rubbing on a 2 or 3 inch lift.
Thanks in Advance.
You will have to lenthen a few ground straps. If you go with a 3 you 'may' need to lower the steering column. Some people do and some don't.
I had 31's on with my 2' the only place they rubbed was against the frame on full lock steering.
1 - 2 of 2 Posts
