just wondering if there are any adverse affects of body lifting my truck. what kit would anyone recomend over others? which come with bumper relocation brackets? any help could be used.
:evilg:
T/A drivin foundin member
adverse affects, shifter height, radiator alignment, cables being to short, raised center of gravity,
your sig. says that you have 31x10.50s, how did you clearance for them??? 31s are my desired size... for now. What gears do you have, i've heard 3.73s are about right.
:evilg: :scary:
to fit 31's
crank the torsion bars all the way
get some lift shackles from auto parts store (mine were 20 bux)
this will allow you to run 31's
however, on full crank they will rub on the sway bar, and on full compression (jumping) they may rub the fenderwells
as for 3.73's i would reccomend them as the minimum for 31's with a 2.8 i like to drag so im upgrading to 4.56's
well, i think that 3.73s should be ok for me, this summer i'm putting in a 350, right now i'm just gathering info but there would have to be something major to stop me.
:evilg: :scary:
say, how would some 31X12.50s clear, any ideas???
:bash: :bash: :bash:
not very well, unless you went with a different wheel or spacers
