Well, it started by knocking and I pulled over to check the oil level(was good) so I precided to drive back home slowly. The oil pressure gauge would drop down to "0" when I took my foot off the gas, but when I pressed the gass it went up to the normal level. Then when I was almost home the damn thing blew. I saw the oil spray out the back. I saw a hole in the oil pan, but not big enough for a rod. It also still starts up, but it won't run longer than a couple of seconds. So does it sound like a blown engine? Or is there a god out there and it's just something not as bad? :dunno:
Thanks
Black SS
Sounds like its blown to hell, you most likely need a long block.
