1 - 15 of 15 Posts
Today, the fuse for the dash/instruments blew. I replaced it and it blew again. Replaced it and the same thing happened. I know what causes a fuse to blow (short to ground). Nothing has been done to the vehicle. No new electrical components. What do you believe I should look into for possible repairs. This has me confused.
97 S10 Blazer 4X4, 59,000, 4.3, Auto.
Early Member
Make sure you are using the correct amp fuse. Check your wiring for worn through spots.
Lt. Schlock
or put a bigger fuse in it.... :)
I hate everyone
well if you know what causes the fuse to blow follow the ground and fix it.. your wiring harness is only grounded in one place...:stickpoke
Early Member
:sheep:
Re: Re: Blowing Fuse
It's not that easy. It's drawing 45 amps on a 10 amp circuit???
Early Member
And this is your dash gauges circuit?
Slow- N- Low
i think i have the same problem.....only my dash and Taillights/parking light dont work but my brakes work just fine........
Discussion Starter #11
There are actually 15-20 interrelated items connected to this circuit. Every one needs to be tested. Royal pita.
i had to wire my parking lights to a different power ource. the guy who had my jimmy before, messed up something when he was installing a stereo. before i rewired it, it kept blowing fuses, like yours. hopefully i can fix it back to normal soon
Fuse blowing
I had the same prob in my 92 p/u. it staredted when i swapped the radio out of my 95 into the 92. my cig lighter went bad at the same time. i unplugged it and no probs since
Discussion Starter #14
Fixed. Turned out to be a fried wire from the a/c relay. Took the electrical shop3 days to find it. Whole dash was torn apart. Replaced the wire with a fuseble link. Cost me $198. I was charged for 3 hours labor and $3 parts. At least it is fixed.
Early Member
Glad to hear you have it fixed.
1 - 15 of 15 Posts
