I have a 91 sonoma. The blower motor stopped working, so I replaced it. A week later the new blower motor quit working. I took it out, there is nothing inside the housing. I tested it directly to the battery and nothing would work. So before I replace it for the third time, I wanted to ask to see what could possibly be frying the motor.
All three settings for speed work. The switch for the defroster, AC, dash, blah blah doesn't work. I only have defroster and off. Any ideas for that?
Thanks in advance.
ASE certified MasterTech
Check your voltage to the blower motor, and yes aftermarket can sometimes be crap.
As far as defrost only, you most likely have a vacuum leak, check all your vacuum lines under hood and under dash/behind the HVAC control head. This is a default safety mode, ensures you can atleast defrost your windshield to see while driving. You could also have other issues, blend door motor etc.... Check all your vacuum lines first.
