many faces
so i have this axle thats out of a 2wd blazer with disc brakes and can i just take off the brkase and swap them over to my drum axle? or what do i need to swap them over?
It's easier to swap the whole axle. you might need to use your old brake hose, I know I did when I did my swap in to a 1st gen. I also had to adapt the E-brake cables, but if you you have a 2nd gen this shouldn't be an issue. You can just swap the brake package, but you're going to have to pull the axles
You have to swap out the axles. The disc brake axles are 1/4" shorter than the drum axles. I did this swap to my Xtreme last year. Was a piece o'cake :)
many faces
ok just pull everything off but the gears then i am guessing cus i have 410 gears in my diff that came with the xtreme package pull axles and just swap i c sounds good thanks guys
