1 - 20 of 29 Posts
BumblBXtreme
i buy from a guy on ebay, hasnt failed me yet. he also gets me the deep blue, green, and pink that people seem to keep asking me for. I use the deep blue myself tho. but they have 8000k like ur lookin for.
http://stores.ebay.com/Xenon-HID-Kingdom?_rdc=1
i want the deep blue for my xtreme! The only thing is i have halo projectors that have the low beam bulb as a h1 but the wiring is still for 9006. There is a conversion from the 9006 plug to the h1 bulb. Would i just get the h1 kit and get rid of the conversion? What does a H1 plug in look like? Is it just those tabs that you push on to the tabs on the bulbs? Any help would be great!
BUMBLEBEE.....you would just get a h1 bulb when u order. the kits come with a standard plug that fits many vehicles. some vehicles that dont fit, they have another harness next to the plug that is just two male electrical clips that slip into ur plug and then you would electrical tape it up. had to do that on the nissan altimas.
http://cgi.ebay.com/ebaymotors/HID-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
that comes with h1 20,000k deep blue bulbs, then they have a standard ballast that plugs into all the aftermarket hid bulbs. my s10 plugged right into that ballast so u shouldnt have any issues tho. So basically if you where to buy that you would specify that you want 20,000k deep blue h1 bulbs when you check out in the comments section of payment.
keep in mind i dont know this person and i dont sell these. this is just someone i have done business over ebay with many times and havent had an issue.
you may also need a relay kit if the lights dont turn on right away or flicker on start up or sometimes dont come on at all. my s10 didnt need it but others have needed it.
BumblBXtreme
but if it has to go through the conversion from the 9006 plug to the h1 would that affect it cu those wires not be to the standard of the hid kit
Nope, it wont effect anything. I'm going to be retrofitting fxr projectors into my headlights, and they're d2s. I already got the d2s hid kit, and the stock 9006 plugs right into it, and the d2s plugs into te other side without a problem!
u wont have to cut wires. the plug socket is h1 but the electrical connections is a male and female connector that connects the the male and female connectors that come from the ballast that power the bulb. the plug that plugs into ur 9006 bulb will plug into the female plug that is the power wire for the ballast.
the red circles are the connections that go from the ballast to the light bulb.
the blue circle is the fitting that fits the factory plug that powers the ballast. the plug that comes out of your 9006 bulb should fit right into that plug.
note that all kits arent all the same. this pic was just as a reference to how the ones that i put links up of are hooked up.
OK
im a total noob at this
can someone help me
i need some HIDS that fit some projector lights and i want some that are deep blue that work for high beams and low beams but that wont rape my wallet
please post links
www.ddmtuning.com
i ordered a set of 5000k 9006 from them with the relay harness and brackets for 60 bucks shipped
i know that ddmtuning has a life time warranty and they are $30 if you just buy the HID's and ballast + shipping so good price and good warranty and i have heard others rave about there products that is why i bought mine from them. i do not have them installed yet but i did put one bulb in one of my headlights and try on and they are bright as hell and i was comparing it to a silverstar.
1 - 20 of 29 Posts
