1 - 2 of 2 Posts
i have a 350 4 bolt main block and i am wanting to build it up to put in a 91 s10. what do all you gurus recommend. i have a good crank, edelbrock intake and carb and heddman conversion headers. i have a set of heads but dont know if theyre good. the guy i bought all of this from said theyre not. i want about 350 hp out of this. what specific parts do you all recommend that work well together. ie heads, cam rods, lifters. should i buy new heads or go to a junk yard or just have the ones i have rebuilt. what pistons should i use? pretty much i want to drive this everyday so i need it to be reliable. i want to build it from the block up so what parts do you all suggest. how much $ am i looking at. thanks alot for the help
footbraker
What casting number are your heads? Exactly what intake and carb? 350 hp istn't too hard to get, unless you have junk heads. The stock crank and rods should be fine, pistons depend on the heads.
1 - 2 of 2 Posts
